1994 Honda del sol Ls/vtec swap for sale
Da1nonly0015
FS: 94 Honda Del Sol Ls/vtec swap $6500
I have a 94 del sol with a rebuilt ls/vtec engine, with less than 12k on it as well as a rebuilt trans with less than 3k. the car is black with roughly 158,00 on body.
below is a list of some of the mods and stats on the car.
5 Speed
98 Ls block
98 Gsr head with Si cams
97 Gsr Trans
Under hood
Je 11:1 compression pistons
Crower rods
Moroso oil pan
Mugen valve cover (repowdercoated candy apple blue)
New starter
New dizzy
8mm Accel plug wires
new Ngk plugs
Stut bar
new brake boster
new master cylinders (both clutch and brake)
replaced proportionate valve
New interstate battery
New aluminum racing radiator and radiator hoses as well as thermostat
new Alternaor belt
Greddy header
Outside
VIS carbon fiber Evo hood
Smoked tailights
black housed 1pc headlights
Type R front lip
Wings west rear lip
del sol brake light vinyl
suspension
skunk2 pro kit fully adjustable coilover kit
control arms
tow rod links
lower strut bar
New front slotted drilled rotors and brakes
17 inch gunmetal rims
Inside
skunk2 short shifter
new black sued shift and ebrake boot
indiglo gauges
tripple pod gauge cluster
new sony rear 6.5"
sony cd player
JL stealth box with 2 8" kicker comp behind the seats
92 prlude seats
trunk has audiobahn amplifier and capacitor
this car needs three things that i can think of
Paint job, it is basicly krylon now but looks decent
new window tint
a damn good driver
i have had the car at the track numerous times at eastside speedway.
the car runs solid 9.5 in a 1/8 mile which for the weight of the car is pretty good.
if you have any questions please ask. If you are interested and would like more info ask or call 540-578-1386 and i will try to get back with you as soon as possible. If you like to have some pics i can send those to you but there are tom many to list as well as I would still need to take some to list on the thread. I live in harrisonburg Va so if you are in this area you are more than welcome to come check it out.
Asking $6,500
Need to get it gone soon, have a baby on the way and need a bigger car.
why on earth did you get rid of the sexy del sol seats for prelude seats.. those things are hideous
Where are you located? Please email me at TSPKMM@aol.com
Thanks
try reading.. damn
