i just won 1k$ spending it on my teggy!!!
quikstr13
i was just wondering if you guys could help me out in finding out more about a hondata ecu for my 94 db7.... and maybe a little more about crower cams.... and maybe even an SiR II tranny...
any help would be very appreciated!!!
Ok I am going to assume you have a LS non-VTEC motor, since you really didn't say so....
Hondata - I think with what you will have (if you go with cams) a S100 setup will be just fine and since your car is OBD1 you will have no problem running it, just make sure you have a good tuner close by. You could go with the S200 or even the S300 but it's not worth spending the money for all that for what you will be running.
Crower Cams - I can speak from experience they are a great cam I had the 62403-2 in my LS but I was way over-cammed go with one step below the 62403-2 unless you are going to bump your compression ratio when you do the cams even though $1K will not be enough to do it all... well properly. When I had them in my LS I put down 146whp and I think it was 127tq not too sure about the torque but it was right around there. All BS aside they are a great cam and I would reccommend them. I just wish I picked the right cam I didn't know what I was doing back then, now I know and I can pass the knowledge.
SIRII Tranny - You will have to ask someone else I don't know a thing about it.
Hope I helped at least a little bit.
GL with your build. :)
sir tranny usually runs about $600-700
And really isn't worth the money.
go with the hybrid Integra transmission :D
1st - 3.230 - LS
2nd - 1.900 - LS
3rd - 1.360 - LS
4th - 1.107 - 99-00 Si/ Del Slow
5th - 0.848 - 99-00 Si/Del Slow
Final - 4.785 - ITR (I believe you'll only find it in the JDM 98+ ITR's)
Crower Cams - I can speak from experience they are a great cam I had the 62403-2 in my LS but I was way over-cammed go with one step below the 62403-2 :)
i was thinking of going with the 403's... but im just curious would being overcammed hurt you performance??? or would i get a better result with the 402's???
im thinking of the hondata s200... just in case i wanna boost later...
just wondering where would i be able to get a SIR 2 tranny???
