hmm.. very interesting
i wonder if you press the supreme 3 times then the middle once then the supreme.... for the supreme type gas
Im trying it for sure !!!
Wonder if it is illegal ?
went to shell
with the filler in the slot i
pressed 93 3x then 89 then 93 waited 10 sec then i removes nozzle and filled to 5.00 pressed 93 and it just kept going....
ill try again on my altima at an older station
is it me or is he just pushing the button twice after he stops at 5 bux... Wonder what country this is in ?
As broke as I am, I think I'm just going to stick to getting anally raped outside of jail. :)
My father-in-law found how to hack drink machines or something. It doesn't quite work tho. You push some buttons in order, and then a menu comes up, and then we can't figure out how to navigate the menu.
I want gas for $1.12...
How would it be stealing if the gas pump fucked up on its own... :)
Well I am still going to try it....
1.12 per liter. Someone correct me on this but I thought it was 5-6 liters per gallon . or maybe more ??
stealing is illeagel no mater what. i think its about 3.5 ltrs to a gal
man I really have to find a place that sells gaz
Most of those pop machine hacks dont work any more. They use to but not so much any more. There are still quit a few machines that let you navigate to the menu to check the sales stats on the machine.
