B18 EF swap ?
EFhatch4
okay im swapping a B18 into my EF...now im using a B16 harness just because it came with the car. The harness is OBD-0 and i bought a OBD-1 conversion harness..now does anyone have a JDM OBD-0 Wiring harness??
wow my bad i mis-typed that..i meant to ask does anyone have a obd-0 B16 wiring diagram
B18A1, B1, C5, which one are your running? it all makes a differnece. If you are staying OBD0 use the harness you have in your car already.everything plugs up the same, minus the vtec soleniod and pressure switch, just let 'em hang
i have a B18a1..i just need to know the wire colors so i can figure out which plug goes..i dont want to get em mixed up.
oh, its the same deal as the B16, just dont plug up Vtec. Once you get the harness in you really cant mix the plugs up, some only reach as far as where they are supposed to go. Dont worry, its not hard. If you mix ep up, you will get a code. just find out what code is thrown and switch whever it says around. lol, its realy all it is to it.
okay..i was going to do that in the first place lol..but ill deff try it out..thanks i appreciate it
