lilredcivicpgh
Yea I want to swap my D16Z6 with a D16Y8 does anyone know where i can find detailed instruction on doing that.
yes you can just keep your stock tranny and axles it will all bolt right upif i do the swap can i keep my trans and half shafts?
you need the jumper there like 70 bucks at rywire mabe more but not muchbut can i keep my distributer? or do i need to get and OBD2 and a jumper cable.
you need the ecu that will run that motor so if the motor came out of lets say a 98 modle buy a 98 modle ecu thats vtec the ex modle.so yea you need a obd2 ecuwat about the ecu or do i need the OBD2 one?
this is true also, i was giving the least of a headace wayI believe you can run re-pinned OBD2 dizzy with an OBD1 car, and not have to convert the whole thing over. Most of the sensors are the same, but the IM may require some plug swapping.
