D16 swap question
lilredcivicpgh
Yea I want to swap my D16Z6 with a D16Y8 does anyone know where i can find detailed instruction on doing that.
its easy. just swap them same mounts and all and will wire right up, all you have to do is convert it to obd2
yea just buy a jumper harness and off you go..
but can i keep my distributer? or do i need to get and OBD2 and a jumper cable.
wat about the ecu or do i need the OBD2 one?
you need the ecu that will run that motor so if the motor came out of lets say a 98 modle buy a 98 modle ecu thats vtec the ex modle.so yea you need a obd2 ecu
I believe you can run re-pinned OBD2 dizzy with an OBD1 car, and not have to convert the whole thing over. Most of the sensors are the same, but the IM may require some plug swapping.
this is true also, i was giving the least of a headace way
