Vtec Oil Pressure Switch
Dasfinc
I need just the oil pressure sender with the green clip for an OBD1 D series Vtec Solinoid, I recieved one without the sender.
I assume the connector is still the same as OBD1 as far as Vtec connectors go?
The head I have is a D16Y8 anyways.
just take the blue not the black the black is a ground.connect that to the wire that goes to the vtec solenoid it should be green. and there you go. you pressure switch is disabled,
Ok ill take 14 dollars shipped. yes i do have paypal. PM me if you want it still. its off of a d16y8 i still have the green connecter on it. you can have them both i dont want to break anything removing it.
