honda parts 4 sale
civic4g63
Everything is OBO lmk guys i am also paypal verified
96-98 ex mesh grill $35
96-98 ac condenser with fan(condenser is crackedbut fan still works)$25
antifrezze bottle i think it fits 92-00 civics $10
crane cams hi-6 new in box used once $128
real hks blowoff valve $160
ractive oil pressure gauge with sending unit $make an offer$
autometer water temp and air fuel gauges with bezel pod fits 96-00 civics $120
aem air bypass valve $30
oem civic shift knob $make an offer$
oem driver side blue side skirt fits 96-00 civic $12
96-98 civic black hood (has some rust spots an sratches)$make an offer$
96-00 oem gray carpet(has some stains no rips)
oem b16 cable gears $make an offer$
2 workin ef gauge cluster $30 each
oem po6 ecu automatic obd1 $60
integra dc2 motor mount $make an offer$
INTEGRA 94-01 rear strut bar $15
mint condition 98 gsr exhaust valve springs all eight $20
gsr oil pan has a slight hair line crack, but can b repaired $50
95 ls head bear head only, head is in awsome shape valves included $60
sohc y8 vtec head has 2 bent valves, which can fixed $90
stock supra intercooler $80
gsr ac bracket $30
oem 07 gsxr dual mufflers $100
92-95 eg tranny top motor mount
92-95 eg lower tranny mount
sohc 98 civic alt
how many stains and you have any pics of the stains? also you have any other parts from the coupe?
what year are those ef clusters? If it's 88-89 I'd like one for mah std.
shipped to 31602?
will they fit an 89 std civic? Do i need the shroud or no?
thanks!
shipped to 31602?
thanks!
45 shipped one is of the clusters is from a crx si an the other one is from a 4door ef
Cluster
I Need A Cluster Very Bad, Please Tell Me You Still Have The One With The Seat Belt Light Between The Fuel And Coolant Temp Gauge. I Have $20 Right Now, Does That Sound Resonable??
