Quick axle question!! b series in eg
This is my first swap. I have a 95 hatch with a d15 and I bought a 95 coupe wrecked that had a blown b18b with a b18c5 tranny. The halfshafts are both bad and am not exactly sure which ones I need to use. Thanks a lot for the help!
and is it the dc teg halfshafts?
-Nick
Make sure you get the correct drivers side one though. The passenger side is all the same but the drivers side is different from the 1990-94 and 94-00. Look at the jack shaft.
If the jack shaft has a female end on it then use a 1990-94 half shaft and if the half shaft is female then use the newer one.
