D series interchange tranny
TegNation
Honda Luv!
ok i just got a 88 d16 hatch, love the car but the tranny just went, i own a wrecked 90 d15 rex, will the tranny out the rex fit my hatch??? Thanks Dan.
yup it dont mater any d series tranny will work
Get an ex or si tranny and rep ME for that one :D. LOL
better yet get a year 2000 ex tranny and convert to hydro + rep me double for that one:D:D
if your 88 still has the 88 transmission, you will need to change the clutch in order to use the 90 transmission - different splines on the input shaft between 88 and 90
ok so one person says its direct fit, yet another says spline change? if true. how hard is it to change the input shafts?
you don't need to change input shafts (not an easy job) - just get a clutch disc for 89 Si or swap the flywheel, pressure plate and clutch disc from your 90 onto the 88 - 90 uses a larger diameter clutch than the 88-89
dude it is a direct bolt one you have evey thing you need, just what ever tranny you use also use the fly wheel and clutch for it
awesome the d15 got a fresh clutch like 50 miles on it when it wrecked!! ok in like 3 days we will see who is right. i sure hope u are ahhvtec!!!
:popcorn: i wanna know, so come back and tell us ok! i have a similar sitch brewing..
