paia_nation
I was wanting to build a b20 vtec, built all motor. Car will be mostly a track car with the acception of driving seldomly on the weekends for car crusies, but not much. I want to make hp to put the car (eg hatch) in the low 11s quarter mile. Was thinking about putting 14:1 compression pistons, h beam rods, with stage 3 cams, pp head, multi angle valve job, 1mm valves, taitanium valve train in a b16 head, all parts from brian crower with toda headers and 2 1/2 in. Piping or slightly bigger.... or Was wondering if I should go with the brian crower stroker kit. With the same stuff as above but just with a stroker crank instead of the stock crank. Is 14:1 cp too much for a b20??? I will be running race gas and tuned with a apex power fc. Thanks
