da wont start!
teggy7
I have a 92 integra and it will turn over but will not start.I was just posting to see if there was a common problem that caused this with this motor. It has new plugs wires cap rotor and distributor. The car ran before it was parked, but now it will not start im going to drain the gas and see what I can come up with thanks for the info.
have you checked your main relay? its under your dash and on warm days or just randomly it will stick and cause your fuel pump not to work. happend on mine
what side under the dash is it on and does it have and distinct markings and how do i unstick it thanks man
its under the drivers side by the steering wheel. kinda hard to see but its black and looks like a relay. i dont think you can unstick it. i just bought a new one at orilys.
buddys got one i can steal off his car if he likes it or not lol ill see what that does for me thanks
i changed it still wont start but i cant here the pump turning onwere bouts is the fuse inside the car or under the hood or a plan b all together lol
should hear the fuel pump click on when you turn the key - don't turn it all the way to ignition position though. if you no clicky u has fuel pump probs.
yes i had changed that main assembly relay and nothin so i think the fuel pumps fried so that will be my next project is there anything els ei could play with to get that fuel pump churnin again like to do witht he sending unit or soemthin
check the wires to see if the pump is getting juice? if you have the bench out they coulda gotten knocked loose..
check you dam ecu fuse in your engine bay that could keep you fuel pump from kickin on
all fuses are good and so is the relay the ecu was changed to see if it was the problem but it wasnt it either
Put jumper cables on it. there's you answer. :) :) :) :) :)
It will start than.
hmmm. i guess he does have a good point. all posts to this point assumed good battery ;)
i ve tried three batteries with the charger still on em as a back up and with out the charger turns over no prblem is the lack of firing thats needed i just have to swap thois pump im hoping
turn your key on and and take off your fuel line to see if your getting gas and check your timing belt tensioner that could of came lose from your block and check to see if your getting spark
my buddy had the exact same problem as me fuel pump wouldnt turn on due to a bad ground so he put his pump on a switch so i dropped the tank and im wiring it up now to see if its gonna work
