DA trans
schmuck
Where can Ifind a cable trans for cheap and what do i need to do to make the swap
:ph34r:Eh im no wise ass but the title states a DA trans, Im hear for help no to piss some one off. Ill make my questions more solid.
Where can I find a Bseries Cable trans and what DO I have to do to replace my old one.
auto or stick ?.....and all yo have to do is unbolt the old and bolt back on the new
R&R (remove and replace), you are going to have to pull your axles, halfshaft, alternator, and probably your right tie rod. While you are at it you might as well resurface your flywheel or get a lightened one and get a nice new clutch also.
Not to sound mean, but if you thought you had to pull the motor to change the tranny then you probably shouldnt be even attempting this. Maybe get a professional to do it or a friend who is knowledgable in mechanics.
