I swapped a jdm zc (zc stamped on block, and crank angle sensor is in dizzy not on cam) into a 91 dx hatch. I purchsed a pm6 ecu, I performed the mpfi swap on the dx harness, and got all sensors wired. The injectors are working, and the ecu has no codes. I'm not getting any power from dizzy plug from the dx harness. I have pulled the harness out and completely unwrapped it to ohm out every wire, they are good still no power to dizzy. When I unhook the grounds at the thermostat I get power to my dizzy, but no spark and nothing else works being that that ground is for the ecu. Could this mean I have an ecu problem, or can I go after market ignition with new msd dizzy, cap, coil, and ignition box please help this is crazy!!!!!!!!!!!
