ef da motor mounts
AHHVTEC
Well-Known Member
VIP
ok guys im drawing a blank, , im putting a b16 out of a ef civic into a 92 da integra, the civic has ha sport motor mounts, i cant remember will those mounts work with the da integra
you don't need a mount kit to install the B16 into the 92 Integra - it swaps right in where the B18 was - just use all of the B18 mounts
lol i know that, i was wondering if the haspot mounts that the ef civic was using if i could also use them on the da
yes i put a b16a into my 90 da using ef motor mounts from hasport... only thing i hade to change is pas. side motor mount cuz the da was an automatic so yes they work perfect
wow!! sounds like we have a breakthrough here - we no longer need to buy Hasport mounts to put a B-series engine into the ED/EF cars! - just use the DA mounts - is this what you are saying? - if Hasport B-series mounts for the ED/EF fit right into the DA, then why wouldn't DA mounts fit right into the ED/EF for a B-series engine? - call me skeptical
good point now im curious as hell lol
He's right. If that worked then mount kits would of never needed to be made other than to have stronger mounts.
