B16 from rex to teg?
hatukazi
ambitious...but rubbish
I got an offer to trade shells for a 90 4 door integra, I was wondering if my B16 swap from my crx is a direct drop in, I know I will have to re-wire the VTEC and other O2 sensor but is the wire harness the same? and will my ECU work? also just a guess but I shouldn't have to change axles should I? If this is more than a 1 day job I dont want to mess with it, my wife can keep complaining about 2 seats:D
Everything will swap over perfectly fine except for the mount kit and shift linkage. You'll need to use the stock integra mounts and shift linkage. Done :D
? did you cut and weld the shift linkage to fit crx. Cuz its too short to fit LS shell. cuz you cutted it and weld it.
then he would need my linkage and mounts for his B18? or diffiernt ones?
+1
O.P, you dont need anything if the teg has the linkage and mounts.
