what intake on a zc?
goldHB94
y8?
aftermarket?
what will work other then stock?
I'm not 100% sure about that, but as far as I know they should all fit.
y8?
aftermarket?
do you mean manifold? - SOHC ZC or DOHC ZC? - SOHC, any D-series manifold will fit - DOHC, nothing but the ZC or the D16A1 (which would be a downgrade) fit unless you get an adapter - here is SOHC intake gasket on DOHC ZC manifold
noooo damnit i hate the way it looks. do you know if any one makes a aftermarket on for a zc?
Damn I don't know of any for the DOHC.. but on the other hand unless you're running upgraded cams and/or a ported & polished head upgrading the intake manifold really won't make much power at all.
Works for me.. you need a program that can read PDF files such as Acrobat reader..
idk much about computers so idk what a pdf is or how to get on can some one post it up as a picture on here?
