take it easy bro. this is my first time. you dont have to be an ass. and for your info the b20vtec will work for an 01 accord.
No, it won't. Do you think I'm an idiot here, or what?
The Accords use F-Series motors, which are completely different than the B-Series motors. The F23 in the Accord displaces 2.3 liters (so that means it's bigger than a B20) and it makes 152 ft/lbs torque (which is more than what a B20 makes).
If you're going to swap an Accord, you wouldn't swap down to a smaller, less powerful motor. You would either build up the F23 or swap to something like an H22 or H23, something that's similar-sized and puts down more power.
The Accord is a heavy car...it needs that much torque to get it moving. Swapping down to a smaller motor would be idiotic to say the least. The after-market knows this, and therefore they don't even bother producing mounts to put a B-Series motor into the Accord. So if you wanted a B20 in your Accord, you'd have to spend a shit load of money to fab up custom mounts, and you'd end up with LESS POWER than the stock motor is producing.
I don't know where you got the idea in your head that a B20 swap would work in an Accord, but you're clearly very mistaken. Go do some reading and some research, and then, when you actually know a few things and you have an intelligent question to ask, come back and START YOUR OWN THREAD!
