dx out and z6 in....what do i need to complete
sasinorm01
i have a dx sedan and would like to put an z6 inside... i have every thing like z6 engine, L3 tranny, and p28 ecu...now what kind of wire harness do i need..
a z6 you say?? still a sohc so the dx wiring harness could be used..provoded you do the dpfi to mpfi conversion..id try and find an si harness
if your car is a 93+just drop it in and run 2 wires and off you go, no need to swap the harness and if its a 92 no need to run any extra wires
it is 89 dx sedan.....so what year and model harness
well i would still use the stock harness and convert to obd1 and mpfi, and you will also need to swap your stock driver side motor mount to the new motor
