Boosted4dr
Asking 5000$ or best offer Or Parting out.
The car is worth more then 5000$ Just in parts
I just moved, the car needs to go.
- black 92 sedan needs body work end of story!
- windows and moon roof are functional
- D15B with 40,000 - 50,000 miles and stock internals runs great.
- sony cdplayer, 4 very nice polk momo speakers, stock and fairly clean.
- short shift - apc
- hks high power cat back system
- onmi power camber +/- 4deg. front and rear
- kyb agx 4 way adjustible shocks
- tanabe sustec df210 2" drop springs
- stainless steal break lines
- tpr junk cross drilled and slotted rotors
- axxis ceramic / metallic pads
- 15" no name junk rims
- 4 toyo proxes 4 ( some early camber wear )
- rebuilt manual stearing rack - new inner, outer tie rods, ball joints etc.
- abs has been removed.
- full set of energy suspension bushing
Fidanza 7lb flywheel
Spec stage 3 clutch ( 2 clutch disks )
Golden eagle vaccum manifold
Walboro fuel pump 255cc
Greddy boost controler
Greddy turbo timer
Stock Obd-1 Ecu
AEM EMS 30-1000
Front mount Intercooler 3.5" x 6.5" x 27 "2.5" Inlet / Outlet
Tial Wastegate 35mm
Tial Blow Off Valve 50mm
AEM map sensor ( Never Wired )
AEM fuel rail
AEM fuel regulator
AEM fuel filter
B&M fuel pressure guage
RC 550cc Fuel Injectors ( Never Used )
Rank 1 Turno manifold w/ wastegate flange
Garrett t3/t4
Unorthodox adjustible cam gear +/- 10deg.
Unorthodox crank shaft pully
There is more i am sure.
Not On The Car Seperate Sale:
- Scat Mfg. H-Beam Rods
- Crower stage 2 cam shaft with Crower springs and retainers
- Crower titanium keepers
- Ferera Intake and Exaust valves
- Race Port & Polished Head needs resurfacing in cylinder 1
Everything listed above for 500$ it also includes the head and block
- short shift - apc
Greddy turbo timer
Stock Obd-1 Ecu
AEM EMS 30-1000
Tial Wastegate 35mm
AEM fuel rail
AEM fuel regulator
AEM fuel filter
Garrett t3/t4
