WTB: 92-95 Gauge Cluster
maxxgraphix
I have a cluster with tach but the fuel gauge is broke. I need the fuel gauge pod to make a complete set. If you got something fubar'd with a good fuel / temp gauge for cheap or a whole set. PM me here.
I have one with no tach (shitty dx) and the temp gauge doesn't work on it either. But the fuel gauge does :)
I had an extra too, but broke the shaft when I tried to swap it in. The DX cluster has the Fuel gauge needle on the other side. So it moves in the opposite direction? Will it switch when used on the tach cluster?
the civics gauges are all electric so its all just a variable power signal to the cluster
