1991 CRX rolling shell picked up (includes all suspention and brakes)
P28 ecu chipped and socketed
OBD0-OBD1 jumper harness (brand new)
91' crx si body harness
91' crx si engine harness convertred to accept obd1 dizzy and injectors
91' crx si dash
B&M short shifter
91' crx si rear disk brake conversion (new remanufactured calipers)
D16a6 Block
2 D16z6 heads one assembled one appart ready for the machein shop
d16z6 dizzy
d16z6 intake manifold with all sensors working
d16z6 t/b boared all sensors work
d16z6 header
p29 ZC standard high compression pistons
d16a6 rods
d16a6 crank
d16a6 oil pan / pump / pick up
d16a6 water pump
DC2 Integra brake booster
DC2 Integra brake master cylinder
DC2 50/50 prop valve
d16a6 freeshly resurfaced flywheel
d16z6 tranny (needs rebuild)
91' crx si radiator and hoses
d16z6 fuel rail and injectors
