loumacri07
Trying to hit 10's
I wanted to see if anyone has any experience with a black widow 12-piece body kit for a CRX. I recently picked one up and want to get as much of it installed own my own before taking it to a body shop. It defiantly trys your patience if you’ve never done something like this before. The parts are not an exact fit and I believe I had the front bumper on and off at least a dozen times before I was content with how it lined up (a lot of shaving of excess fiberglass). The fenders weren’t too bad. Actually, they are probably the easiest part. I’m working my way back and this is where I start running into some uncertainty. For the door panels, do I put them over the existing sheet metal or do I remove the sheet metal? I’d like to remove what’s there to keep it as light as possible, but will doing so impede on the doors structural integrity? My next question is in regards to the quarter panels. Since this kit is a wide body kit the gas tank lid needs to be moved. Again, can I remove the sheet metal and use panel glue and just the fiberglass quarter panel, or do I have to go over the existing panel? Please correct me if I’m wrong, but I am assuming I can have some tubing welded to the fuel tank fill line to make up the gap. Lastly, the kit didn’t come with a fuel lid. Does anyone know where I can get aftermarket fuel doors or would I be better off just fabricating something out of fiberglass? Any advise, if you have worked with this kit or not, would be greatly appreciated. I’m pretty sure this isn’t the only kit that would present these issues I am trying to resolve so any feedback would be helpful
