what is this and were does this go
kermit5327
so confused help please????
can anyone tell me what the things that are circled what they are and the hoses with with the blue on them is that were it is suppose to go and the little nipples that dont have hoses on them were do they go to thank you and once again im new to doing this stuff to my self
and the hoses that are red yellow and green is the way i have my vacuum lines ran for my blow off is that the way that they should be ran
hey man i got the car how it sits pretty much and it is running there is just a few things that im not for sure about
well come on now i didnt post to here your guys shit i post on here for help and to get to know other ppl and i like i said i got the car pretty much how it sits turbo and all the only thing i did was put a different motor in it i didnt have a header to put on the car to work every thing out first and the motor is only going to be in there for a little bit longer so either you can stop trying be a big e gangster and help me out or you can just stfu and piss the fuck off
LOL. I think the only thing you're going to get is a big ban from the forums for flaming. I'm not a mod and I can't do that, but you might want to edit that post before a mod bans you so you can actually have your chance to get help.
Good luck tho but I don't know of many people who would turbocharge a motor without everything hooked up first. Just my .02 and if I'm misunderstanding something, my bad.
we dont ban people for insulting chris. those that do, just help us complete our mission when we are busy doing other things.
as for your questions.
i can tell you that this:
http://i79.photobucket.com/albums/j142/kermit5327/Cars/honda/IMG_0275.jpg
goes to the sensor that should be on this:
http://i79.photobucket.com/albums/j142/kermit5327/Cars/honda/IMG_0277.jpg
At least im pretty sure thats what it goes to...my prelude's intake has a similar look to it and i have a sensor right there.
That plug would be to the MAP sensor. You should have a sensor near the fuel pump that faces the intake manifold and that plug won't reach it you'll have to cut the piece holding it up there so you can move it a little bit. I had to do it for my d15b vtec swap.
Make sure it's not confused with the TPS sensor because both of the plugs were the same on mine and I had them backwards at first.
The MAP sensor should be just to the right of the fuel pump.
And I just noticed something that pic you have of that hole on the back of the head. There's usually a hose connecting your intake to that hole.
ok thats what i thought i just wasnt for sure about it now all thats left to figure out is were the nipples go hook together at
Fuel pump under the hood? WTF M8?
