HELP ls engine swap in a 90 crx
crxhoppa
crx project
i blew a piston ring in my 1.5 crx and now i want to swap the engine and i talked with some guy and he said that an acura ls engine and tranny will drop right in and blot up and wire right up. is that true? if thats is true what else would i need to get it all running right?
i am sorry if i post this in the wrong place i am just new to this. thanks
the 90 and up Integra LS B18 engine and transmission will not bolt right into your CRX - you would need an aftermarket mount kit, shift linkage and axles in order to install it - you would also need to convert your wiring from DPFI to MPFI - you would need the engine transmission and ECU from the Integra
as he said^ it will not bolt up......tell whoever told you that to bend over so you can kick them in the ass
haha u kno thats wat i was saying but i was just makin sure i was right. thanks guys.
now what is the best engine to use in a crx that will just bolt right up and wire up besides dpfi to mpfi but also give it more hp a little bit?
Well for that matter a D16A6 will bolt right up no problem, as well as any other D-series motors.
But on the wire right up part, som motors need a few wiring modifications depending on the motor you choose.
dont forget the hubs.... alot of ppl tend to leave those out of the swap lol
i would personally swap in a D15b.... decent lil motors and they tend to take some abuse, then slap on a lil snail :D
id do a minime swap or just put a d16z6...or look at the sohc zc(it has vtec)
