im lost
89civicsnatch
I scored this free manifold. But whats it fit? The tps is a 3 wire and points down to the ground. there are 2 ports on the top one runs to the fuel pressure regulator wich is bolted to the fuel rail. the othe runs to your PCV. the EACV is a 2 wire and 2 vac ports. The IAT is located in the back of the #2 intake port. it is also a 2 wire. if you need to know anythign else ill do my best to answer
ok so this is going in to a 4G dx wich is MPFI the motor is in a 90 4dr DX with the DPFI manifold on it.
