Reckone
EF aholic
I need to resize my collection of parts. Everything is OBO! Prefer local pick up on bigger items! Price's are for one item only, I have muiltiples of the same part.
Paypal, MO's and cash!
Located in Albany, NY.
-----------------PICS AT REQUEST---------------------
---94-01 Integra Parts---
Tan leather rear seats $40
tan dash $50
rear tan plastic, complete set $50
1-Under dash panels blk $5
2-gauge bezel blk $5
tail lights w/ amber corners $60
passenger axel $30
front spindles $50 pair
rear trailing arms/ no calp no rotors $50
stock muffler, axel pipe cut off $30
2-Stock mid pipe $40
rear LCA's/ needs new bushings $30
front swaybar $30
rear swaybar $40
rear stock struts/springs $40 both
Front stock struts/springs $40 both
2-complete rear seats/ great shape $50
dome light $10
headliner $10
complete sunroof $40
pass front window $25
Drivers front window $25
door panels, purple/blue cloth $50 both
window switchs w/ handle both $20
door lock switch both $15
98-01 headlights $75
glovebox blk $25
front seat belts $25 both
2- master cylinders $25
2- prop valves $15
16- 14" Acura hub caps $10 each, $30 set
---92-95 Civic EX 2dr---
sunroof switch $15
front calipers $30
center console, cupholders-back, gray, auto $40
master cylinder $25
front corner lights $20
passenger front fender, one ding, white $40
prop valve $10
---88-91 Civic HB parts---
90-91 corners oem $10
90-91 oem bumper lights with harness $30
Drivers door , primed blk $40
passenger door, primed blk $40
steering colume w/ tilt $25
front dx spindles w/ hubs $40
dx front calipers $25
DX stock rear bumper cover blk $20
DX blk door panels 90-91, cloth inserts $40
---88-91 CRX---
Both front fenders, blk mint! $160 both
rear cargo compartment, blk $40
88' si door panels $50
sideskirts oem $30
88' si pass seat, mint, grey $30
blk center console $20
rear si triangle pieces, clips broken $25 both
front 88' si bumper cover, blk $60
rear 88' si bumper cover, blk $40
center console(e-brake cover), blk $15
radio bezel, blk, no ash tray $30
88' SI gauge cluster, 135K $50
shift boot $10
---ECU'S---
P28 auto $110 shipped
PR3 B16A auto obd-0 $110 shipped
---Engine parts---
complete A6 motor, spun a rod bearing, still runs 180k $150
B-series hydro EF motor mounts, never used $75
91' CRX SI 5spd trans $200
D16A6 head 140k $75
Z6 oil pan $30
Z6 complete intake mani, auto, needs TPS $45
90' Si complete intake $45
Bare a6 mani/ TB $25
D16A5 head, 8 valve $25
dpfi intake mani $10
D16Y8 head, no vtec sol $100
Tuner toys B-series H-beam rods, brand new $200
3-d-series flywheels $20
d16a6 crank, needs to be checked $30
D16A6 rods and pistons $40 set
B18B1 starter $25
D16Y8 distr. cap and rotor NEW $10
10- OBD-1 injectors $5 each
---Turbo Parts---
t3/t4 XS Power turbo, needs rebuild $75
Voo Doo vacume manifold 6 ports, polished $30
---Misc---
95-01 Dodge Neon pass fender, blk $50
01-03 Neon tails stock $25
97' Kawasaki KX80, fully rebuilt $700
87' Honda XR600R $800
tan dash $50
passenger axel $30
front swaybar $30
rear swaybar $40
dome light $10
headliner $10
glovebox blk $25
2- prop valves $15
sunroof switch $15
front calipers $30
master cylinder $25
prop valve $10
---88-91 CRX---
sideskirts oem $30
shift boot $10
---ECU'S---
---Engine parts---
D16A6 head 140k $75
Z6 oil pan $30
B18B1 starter $25
---Turbo Parts---
---Misc---
