Turn signal blinker help...
93civicracer
Oh, I do a little here and there.
Since I swapped my d15b vtec my front right blinker won't blink when I use the turn signal. But the light WILL come on when I put the lowbeam on, it just won't blink. What could this be? All fuses are fine, replaced the bad ones, ecu has been reset, idk. My interior light isn't working either.
Suggestions?
lmao seriously I can't figure out why the fuses are all good I just replaced every single fuse in the car and the thing still won't blink when I hit the turn signal on. It comes on when I put on low-beams tho.
I know...shit I'll try filling up the blinker fluid like you said.
your turn signals should have two separate bulbs, one for your parking lights (which come on also with low beams) and one for the turn signal. i am pretty sure your turn signal bulb is burned out :)
Seriously there's 2 separate ones in there? Damn I thought it was only 1. Thanks I'll get to it in a minute when I put on my new pedals :D
yyyeaaahhh... on the crx for sure and since you have separate turn signals (separate from headlights) i would put money on you having two bulbs in each turn signal housing. not that i am a betting man though...
no you're right, there are two bulbs. i guess i kinda assumed the bulbs were good :D
