Heyy ..!!Ive got a b20b whit a b16a vtec head and b16 tranny..!! ^_^
Once i was driving and the car spontanyously STOP..! and wouldnt start ..!!
Ive check every thing... spark plug fuel railing,cap dis... fuel pressure..!!
Somme time i crank it ,,!! it`s starts but i seams like it`s running on 2 ou 3 piston..!! if i give gass i doesint go hi on rpm and runs like a harley davidson and stalls.!!
I dont really know what to do..!! sometime the ecu gives me the 15 error code which is a Ignition Output Signal but my ignition seams to work well since the starter is actually turning ..!???! I dont know what to do and i cant bring it to the garage coz it wont run..!
Im gettin spark.. mabe it`s not a good spark or it`s probably a ground some were or a sensor of somme kind..!!!
Cannn somme one explain in detail what the hell is the Ignition Output Signal error code and HOW can we fix it..!!! ive look out tru the web but i hazzint help me allot..!!! Ive seen stuff about ignition key panel taken off and replace the ignition thenn ive seen stuff about running a wire from ur positive batteri to the neutral cluthc of whatever..!!
Cann somme one help me PLEASEEEEEEEE^_^
