k...im thinking about boosting the h22...can anyone tell me how much boost can it safely handel with stock internals....
It's slightly more complicated than that. A lot of it depends on the quality of your tuning. A motor that's tuned well can handle a decent amount of boost. A motor that's tuned crappily or not at all is likely to blow up after too long.
What are your plans for tuning?
would buying a chipped ecu solve it..??
That's part of the answer, yes. But a chipped ECU isn't a "one-size-fits-all" solution. A chipped ECU needs to be programmed and tuned specifically for whatever engine setup you're going to be running.
and sending it to mugen and telling them what parts are on your motor does NOT count. good tuning can ONLY be done with the car in front of you.
well my buddy uses his lab top..he hooks it up to his ecu and does everything so i guess i could do that and be my best bet..?h22 stroker kit...drop compression..might be costly but for high boost right?
