Rywire Vtec harness
93civicracer
Oh, I do a little here and there.
I want to wire up vtec in my jdm d15b vtec swapped dx, it's a 93 dx and I was wondering if this harness will work. It's for a dx to d16z6 but I'm not sure if it'll work with a jdm d15b, anyone know for sure?
Not too sure you should just hit up Rywire and ask them directly. Rywire is awesome they will take care of you.
or you could just run the two wires yourself and save a little money :)
solenoid (one wire plug) - A4
Pressure switch - D6
Pressure switch ground - A26 (or can be grounded to the head)
Yes, that's exactly what you need.
True, but then again, how much money is he really gonna save? The harness is only $40. He'd have to pay for wires anyway to do it himself. To me, it's worth it for a nice, clean, easy install.
I was saying to ask Rywire if it will work before you buy it not to have them wire it for you. You would have to drive a long way for them to wire it for you, by the way their wire tuck jobs are unreal clean.
I don't think he was suggesting that Rywire actually install it for him, he was just saying to skip buying the pre-made wiring and just wire it up himself. And my response to that was: the Rywire harness is only $40, and it makes for an easy and clean install, so why not buy it?
Werd I fully agree with you.
Great thanks for the responses. Just gotta check the timing, fix the coolant and engine oil leaks, clear the ecu codes, put in some suspension bolts I left out when I did the swap and then I'll be buying the harness and wiring up vtec. lol
JESUS H. CRIMONY!! buy the harness from rywire..simple plug and play. yea you can do it a lil cheaper yourself but its worth the money trust me. simple..simple..simple.. my d15b's vtec works flawless! wires will be there already..,just match the colors..and bam! wired up that vtec yo!!
