or you could just run the two wires yourself and save a little money
I want to wire up vtec in my jdm d15b vtec swapped dx, it's a 93 dx and I was wondering if this harness will work. It's for a dx to d16z6 but I'm not sure if it'll work with a jdm d15b, anyone know for sure?
I was saying to ask Rywire if it will work before you buy it not to have them wire it for you. You would have to drive a long way for them to wire it for you, by the way their wire tuck jobs are unreal clean.
I don't think he was suggesting that Rywire actually install it for him, he was just saying to skip buying the pre-made wiring and just wire it up himself. And my response to that was: the Rywire harness is only $40, and it makes for an easy and clean install, so why not buy it?
Great thanks for the responses. Just gotta check the timing, fix the coolant and engine oil leaks, clear the ecu codes, put in some suspension bolts I left out when I did the swap and then I'll be buying the harness and wiring up vtec. lol
