looking for a b18c1 gsr with tranny
BIGJOSEPH
Big Joseph
i pretty much am looking for everything to do a gsr swap in my eg, motor, tranny, mounts, axles, shift linkage, ecu, wiring harness, perferably with the engine and tranny fully assembles with harness and ecu but any help would be appreciated. thanks
I have a GSR swap I'm parting out. I have the GSR P72 head, transmission, axles and halfshaft, mounts, shift linkage, P72 obdI ecu, and engine harness. All coming out of a EG with GSR swap. Located in CA, and willing to ship. Posted on honda-tech under mikaleg6.
Quick question, sorry for jack,
If you had a B18c1 with type R tranny and you wanted a clutch, you the clutch fit the engine or tranny?
i have an obd 2 Gsr swap only thing you need is the mounts, converted to obd 1 all you need is the mounts 3000 shipped. and i have all the paper work on the motor.
Nothing it will come with the obd 1 harness and like I said all you will need is mounts. And drop it in and go. No Tranny grinds motor is in great shape I got the motor to put into my ls integra and it got wrecked so now I need the cash.
Re: BIGJOSEPH
whats the specs on that motor.
200 HP, 137 TQ, 11.1 CR
JDM ITR block
JDM ITR head,
JDM ITR LSD transmission with 4.4 final drive
JDM ITR P73 ecu
Mounts, starter, alternator, clutch, ITR flywheel, axles, shift linkage, intake manifold, exhaust manifold, fuel rail, injectors, distributor, engine harness, comes with all sensors needed.
Motor average of 40k miles, and is a complete swap.
i have a gsr in my integra its 94 has miles but runs awesome no grinds to burning oil etc and im close to you im in maryland i dunno if the mounts will work or not there the stock integra gsr ones that something u would have to check into let me know id sell for 2900
