1989civichatch
jdm
hey guys im new to the eg scene... but i now quite a bit about ef's, what im gettin at is what all is neccesary in order to swap a gsr into a 93 civic dx
i pretty much all the main necessities becuase i did plenty of research on the b16 swap into an ef, i just wannted to find out a little bit on the swap
basically i need to know if the axels from a gsr will work on the hatch, along with the shift linkage, and what motor mounts will i need to use? is there a specific genereation gsr motor i should swap in (as in being the least complicated/ most compatible), the eg's are obd1 correct? so i will need an obd1 gsr?
idk i just need some help
