Howdy folks!
just wondering where would be the best place to start modifying with the accord.
SOHC F20B, VTEC.
Do i start with lowering the suspension or would you go for engine mods first?
Theres a place not far from me that specialises in Jap motors, and said he can do loads with it, even turbo / supercharge it (but that'd be £3k, so i'll pass).
he's on about stuff like:
Oversize green air filter and re-location pipe
cold air ducting and heat shielding
4 into 1 heat wrapped manifold
2.5" exhaust system
Uprated cams
Uprated valve springs
Uprated con rod bolts
shim under lifters
vernier pulleys
head machined for high valve lift
head skim
extensive porting work
Megasquirt ECU
All that fitted, would cost me no more than £2,500. ($4,961)
Whats your opinions?
SOHC F20B, VTEC.
2.5" exhaust system
Uprated cams
shim under lifters
vernier pulleys
head skim
Megasquirt ECU
