I need help?
BIGJOSEPH
Big Joseph
On a 96 civic coupe with a 2000 ls swap, i got a check engine light on because there is two harnesses for the o2 sensor and the header i got only has one 02 sensor hole, i need to know what would be the easiest thing to do was weld a 02 sensor nut and drill a hole in the header or can you hardwire it in. any help would be appreciated.
can i just drill and tap it or do i need to weld one of those 02 sensor nuts on it, and the 02 sensor in it now is on the far passenger side pipe where does this one need to go.
your gona need to make a hole then weld on a nut so you can screw the 02 sensor in
idk if it is the secondary the one that is plugged in is in the far passenger side pipe.
well i went by the parts store and they said for that motor there should be one behind the cat, what should i do.
coo then just tap a hole at the bottom where all the pipes come together and make one pipe , and put it there it will be fine
should i buy the oxygen sensor that is supposed to be behind the cat. and put it in the header
do you not even have the stock one ?, but yes if you dont have it buy a secondary 02 sensor and put it where i said and the cel will go away
