B Series Axle Question
HATCHET_HONDA
scottie fizzle
anybody know if the steering knuckles from the 90-93 integras will work for a b16 swap in an ef? i cant find any ex sedans but plenty of tegs
then i will need to use the intermediate shaft too righ? cause it seems the abs axles are the only ones i see that have the female end to attatch the shaft
The DX and LX knuckles are the same as the EX knuckles too. Pretty much all EF-ED knuckles will accept B series axles except for the knuckles from a CRX HF or the STD (4 speed) hatchback.
You're gonna have to use the 90-93 integra intermidiate shaft no matter what knuckles you use and the 90-93 integra axles are the same weather they are ABS or not. The ABS ones just have the ABS ring on them...
is there a 3rd axle then? cause on ebay they have the b16 swap axles but they have both male ends so thats why i was confused to how they would attatch to the int. shaft. i was thinkin it would go from the pass side to the trans then drivers side to int. shaft the an outer axle to the hub.
This is how it goes...
Driver Side...
hub:<axle>:IntermidiateShaft>:tranny:<axle>:hub
:=female end < and > = male end
i get it now! the intem. shaft goes into the trans........ i feel dumb now lol i was thinkin the axle slid into the shaft on both ends. thanks for the lil illustration :)
Driver Side...
That's actually a wonderful little diagram, but I can't even IMAGINE what kind of misconstrued sexual innuendoes someone else might see, assuming they weren't a part of the conversation already.
... that's just dirty.
if u do buy DA knuckles, u need to get the calipers too. i have a std. hatch and that is what i had too do
plenty of teg knuckles in the boneyards round here..not sure the shape that the calipers are in..prolly have to pick up new ones
w0rd. i swiped rear discs from a '90 teg but they were so rusty and the seals were in such bad shape I ended up getting remanufactured ones from the acura dealer and gave the junkyard ones as core deposit. they were $450 minus 2 $60 core fees. so i payed like $330...
i'm stalking you around the forums man, lol. i hope your makin good progress, cant wait to see it!
lol.... well i just found a gsr head for the b16 hatch and im havin problems with the p28 ecu in the black hatch..its not reading codes...think i could swap in the p30 that i got for the b16 and see if the ecu is truly the prob? its kind runnin like crap..stallin and idlin funky sometimes
is the P28 running a D16 in the black hatch? i dont think a P30 will run a D well, it might tho still.
o i saw you drivin like a week ago in hobart. revin up 1st gear. lol
