b16 built head want feedback
Wilshire
Big WIll
im about to build my head and just want some feedback
heres the parts list
buddyclup spec 3 cams, dual springs and cam grears
skunk 2 titanium retainers
Rc 68mm tb and tpye r intake mani
Port match head to mani
Skunk 2 1mm oversized valves
and some mild port/polish work
cometic head gasket
so... tell me what you think.
as far as hp gains i am thinking 20-30 to the wheels, is my assumption correct???
thanks
no.... you won't lose compression with the cam, but the 10:1 compression of the b16 is far too low to make those cames worthwhile. the thinner gasket will net you +.1 or .2 ish, so 10.2:1
ideally, you want 12.5:1 compression or more for those cams.
you'll probably lose a ton of power until 5500 or so. and up top make a little more.
i'd do some pistons while you got the head off.
