Drive shaft question
richievti
can i use my 1.5 vtec e drive shafts when swapping with 1.6 b16a2,
Please could anyone help.
Thanks Richie
No, you need the intermediate shaft. B series axles are approximately the same length whereas the D axles are long (driver side) and short (passenger side), so you need the int. shaft to span the back of the block. A simple search would have yielded the answer to this question though.
ok, thanks for the info. Does the axle that goes into the int. shaft have a lock ring on it also?
