Are you including the approximate $1k it'll cost you to drop a B into your car?
it can run pretty expensive after all is said and done. plus it's a little more complex swap. you will also run into smog issues with it.Why does nobody mention the H22 anymore? I would think you could do that swap for under 3200.
you can, but the question was whats the best motor not the most powerfulWhy does nobody mention the H22 anymore? I would think you could do that swap for under 3200.
alot of ppl i've saw talkin bout h22 swaps into civics like mine, have said they had to cut some of the engine bay for the h22 to fit. i'd love to have that engine though. has 200hp and 160tq. thats some power.
thats not power!
Now THIS is POWER!!!
i was wondering what would be the best engine swap to get for the max 3200? i have a 94 civic ex.
If $3200 is the limit of your budget, you can't afford to drop a GSR into your car. You can afford to buy it and look at it until you get the money to swap it in, though.
