Weird vtec problem. Please help..
1slowEF
So I bought a 91 Civic with a 94 GSR swap. Vtec will only work if directly connected to a toggle switch and will bog in and out of vtec at around 6k +. Always done this since I've had it. Any ideas?
Things changed/checked.
Oil is fine.
Rewired vtec and other sensors.
Changed vtec selonoid.
Tried other virgin/chipped ecu's.
Running str8 pipe, so no cat.
And only CEL on throwing is 6 Engine coolant temp sensor, and thats because it's not plugged in.
Things that I think can cause the problem.
Preety bad dented oil pan.
Don't know the condition of either oil pump or oil pick up.
And maybe fuel, even tough fuel gauge reading 50 at idle.
Please help..:mad:
if you dont plug in your coolant temp sensor you will not have VTEC because the car will be in limp mode.
Fixed the sensor, so no more CEL. Also vtec works propely now, no more vtec button. But is still has the same problem..:(
i had the same problem with my b17, could never figure it out, made no sense
Umm Ummm Do U Feel The Motor Has Lost Power When U Drove A Civic W/ 94 Gsr Motor Swap ? Cause I Had A 95 Honda Civic Coupe W/ 2001 Acura Gsr Motor Swap.. So 1st All I Want To Know If U Feel The Motor Don't Give U A Power On The Wheel ?
Umm Ummm Do U Feel The Motor Has Lost Power When U Drove A Civic W/ 94 Gsr Motor Swap ? Cause I Had A 95 Honda Civic Coupe W/ 2001 Acura Gsr Motor Swap.. So @ 1st All I Want To Know If U Feel The Motor Don't Give U A Power On The Wheel ?
my ls-vtec did the same thing, turned out to be an oil pressure problem. if you know your oil pump is good, try changing brand of oil lol. I know it sounds weird, but for some reason, Castrol GTX 10W-40 did the trick way better than Penzoil. I def. wouldnt go thicker than 10W-40 though
Is it wired to obd1 or is it the usual obd0 with the obd1 jumper harness? What ecu?
MOBILE 1 =)
10w30 can use it on gsr ?
