93civicracer
Oh, I do a little here and there.
Alright so since I've wired up the vtec which is working fine I started having radiator fan issues. The fan doesn't come on at all now, and I've checked all connections they're good so I think it could be either the motor or the relay.
And another thing, now when I start the car, there is a little shock on the transmission ground. The part where it's grounded to the frame, it shocks right there when you start the engine. And now, everytime I rev hard, when it settles back down to idle it idles really low at like 400-500 and the car rattles from it. Any ideas on that radiator fan not coming on and the shock at the ground?
The fan used to come on right when you turn the key before you even start the engine.
