91 prelude h22 swap
dr.crankenstine
I have a 91 prelude and i am attempting a h22 swap. i dont want to have to reset the homemade mounts 4 or 5 times trying to get it right. i want to know were i can buy motor mounts for a 91 prelude h22 swap. also find out if i can use any of the 91 mounts or exact demensions on how to make them.:huh:
3rd gen h22 swap
There are mounts you can get they are around 375.00 to 475.00.I just bought a set .Im looking for a plug and play harness for this application if anyone knows where i can find this.If you need axles for this swap raxles.com has them for 360.00 a set.Anymore questions hit me up.
what year lude do you have???
but look into Rywire they have what you will need
Here is the link to the most informative writeups for the H22 swap into the 3rd gen chassis:
3rd Gen FAQ/Resources - Common Fixes, Manuals, Write ups, etc - Preludepower.com
Its on preludpower.com
As for the wiring for the conversion, uncle Buck is correct, just email Ryan@rywire.com and they can do the harness conversion for you.
Mounts are sold through me since I had them produced and did all the nasty hardwork to get them produced.
I sell the mounts for $475 + shipping and any paypal fees, but I also accept money orders.
Anyone can contact me at: onefunrydperformance@q.com
Or pm me thru here as well.
And sorry but AZ Race will not give out that information for the dimensions, they worked to hard on this project to just give up all the secrets.
Sean
(206)304-4095
i as well have mounts for this swap but your not going to find a plug and play...u need to make a harness out a obd 0 integra harness unless yours is obd 1
Or just send your original harness with the H22 harness to www.rywire.com and they can do it for you and then it becomes plug and play.
I have done most of the work to make this swap as simple as possible within reason. Obvisouly if you do not have any experience then you should pay someone to do it. But i have had all the parts manufacured for mass production.
Sean
if i modify an obd 0 integra harness, will it still plug into the cassis plugs on the shock tower????
