d15z1 build?
On such engines, would it be possible to swap out the head? I didn't realize this was a VTEC-E until you pointed it out.
this is what i want to know as well. i think the "econo" version is all in the head. if i swap out to a y8 head i should see gains right?
Of course, if this were possible though. That is something I am not able to tell you. Someone else like Blanco or one of the other knowledgeable people around here might be able to answer that question. My suggestion to all is do like I have and research the hell out of the topic you're looking for.
I would think since you have a D-series block, that another D-series head, such as the D16Y8 head which you mentioned, or the D16Z6 head should theoretically bolt right up. Switching the heads will add power or gains, if you will, to your build. Best of luck to you guys. Keep me informed as one person can never learn too much. :D
