Pushing oil out new gasket
MazdaAspec
/\ IDIOT ALERT /\
I just replaced a gasket on the VTEC switch. I fixed the problem but it was only fixed for a day and then I found out that I was still pushing oil out this gasket. I have 12.5:1 CR and not sure if that is the problem. What could be done to fix this problem if there is a fix to it so it will stop leaking oil out that gasket.:(
make sure both surfaces are really clean(i use brakleen or carb cleaner)and make sure to tighten the bolts to spec
Hey, maybe you are using slightly wrong gasket for vtec solenoid -
for example b16a Sir1 engine needs gasket off 90-91 NSX.
Search the forum for those keywords for the part #
