HELP finished manual swap running like sh*t 92 accord
BigSpec007
Hello all, I'm a noob on this site and need some help, I just finished an auto to manual swapon a 92 accord as well as engine swap, all stock just rebuild nothing fancy is for a friend of mine.any way I finished the swap mostly the reverse lights still havent been worked out but this problem is about the engine. Runs like crap wont rev over 3000rpm lacking power,idles just under 1000rpm, it idles fine but when your driving the car cannot get out of its own way. I did change the ECM from the auto to the manual,and we did have a problem with engine harness, but it just lacks power.
Any suggestions?anyyone?
where would I find reference on checking the codes for a 92 accord i searched with no luck but i will keep looking
Bridge the little blue plug under the right side of the dash with a small piece of wire, turn the key on and count the number of times the check engine light blinks. Should be in the manual....I assume if you did a trans swap you have a manual.
