D15Beater
HNFTuning
I need some help with this transmission. I got it under the impression it was a ls trans, but the input shaft bearing was worn out. So I crack the case open and wasnt surprised to find the input bearing was missing quite a few of its balls, I found them at the magnet, squashed into little metal curly fries. Thats nothing I can fix the bearing but I got curious and counted the teeth on the final drive gear. Its a 66 tooth count, thats a 4.40 FD and according to this guy Specnically Speaking: B-series Gear Ratio Guide + More! the LS trans didnt come with a 4.40, it came with a 4.266. This got me curious enough to count the teeth on both the mainshaft and the countershaft....
Results... Main Counter
1st 12 38
2nd 21 39
3rd 27 34
4th 31 29
5th 35 26
Final drive = 66 4.40
Can someone back this up....Im curious....if this is a B16 transmission
2nd gear info is correct, I counted the teeth on the counter shaft 3 times....
1st 12 38
2nd 21 39
3rd 27 34
4th 31 29
5th 35 26
