402streetracer
I just wanted to check before i start to pull off the side moldings on my 95 civic sedan, is it just held on by adheasive or some type of clamp/snap-in sort of thing,
JDM EG '92-'95 Civic Sedan Side Moldings (Clip) | JDM Honda Parts, JDM Honda Engines / JDM Nissan Motor Swaps, Used JDM Parts - Password JDMThere's going to be a ton of holes in your door when you pull them off...
Oh and I'm looking for the JDM thin side mouldings, I can't find them anywhere for a sedan. So if anyone knows where to look, point me in the right direction.
well the molding covers the holes up when you put the molding back on, but if you want to take the molding off for good you will need to bondo it upok, so what would i need to do to fill those holes welding? orrr?
this is correct, but either way bondo will be neededthe right way is welding them
i bought some clips at canadian tire, they suckt and i just went to honda....well why where on the topic where can the molding clips be bought besides honda..because there 4 bucks each at honda
