mistuhannd
okay so me and my friend were installing his coil overs yesterday in a 94 accord, we had gotten the front installed, and moved to the rear when we were removing the bolt that held on the bottom of the shock, it took a while before it broke but it eventually did.. and so we kept on turnin the wrench and the bolt wouldn't come out, as i go to look under the bolt is already out of the thread and it stretched the end of the shock and also when we turn the bolt the bushing inside spins with it at every turn, the bolt is still stuck im thinkn the bolt is rusted on the bushing... i need to kno whats the easiest way to remove the bolt and the bushing so i can get a new one and is it safe to drive the car without the bolt being bolted in the thread because its pretty stuck and what is the name of the bushing?? thanks n advance
