RwD_crx_06
will the 37820-Pm9-a01 ecu work on the 96 d15b vetc with 4 speed manual trasnmission ? or do i have to put the p28 ecu with the chippin or without chippin on 96 d15b vtec ? please help! thanks
Yes, the P28 will work assuming the motor's OBD1. If it really is a true D15B VTEC it came from a 92-95 rather than a 96. If it's some kind of Mini-Me using a 1.5 block but a newer head, then you're going to need an ECU compatible with whatever OBD system you're using.
i think its 92-05 d15b vtec am not sure.. because the guy who sold the motor to me he said he dont know as much about the d series things anyways i guess i will put a virgin p28 ecu on d15b vtec. thanks for your time!
sure i will put the p28 ecu in the car. hopefully its will running pretty good.
In order to run a p28 in your 1996 civic, you have to understand a few things...
1) your car is obd2a
2) a p28 is for obd1
3) you will have to buy a jumper harness (obd2a - obd1)
4) you must use an obd1 distributor
5) you have to use the proper p28. If your manual transaxle, than you will need a 5speed p28. If your automatic, you will need a p28 from an automatic.
Yeh I know, but I got a 96 d15b vtec engine swap into 91 civic crx. That's what I am asking for.
Has the car been converted to OBD1? A 91 uses OBD0 I believe...
correct, a 91 uses obd01 but i can get the 92-95 harness wiring comes with the ecu plug.^_^
That's what you would need...either that, or have someplace like Rywire (Rywire - Online Store) make you a conversion harness.
maybe i dont need the rywire make me a conversion harness cause ill get he 92-95 harness wiring comes with the ecu plug. if there need to rywire make me a conersion harness. i gotta to see what i am gunna to do with the harness wiring.
